Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Make sure the device is powered off. Gently insert a spudger into one of the bottom corners between the screen and body case.
  • Make sure the device is powered off.
  • Gently insert a spudger into one of the bottom corners between the screen and body case.
  • Slide the spudger along the inside of the crack in order to pry the case open.
  • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
Hier Übersetzung einfügen
