Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
After the cover has been removed, unscrew the M1.6 x 2mm screw from the battery cable with a j000 Philips head bit. Using screwdriver bits that do not fit snugly in the screw head have a tendency to strip the screw and render it unusable. Remove the tape by gently scraping the edges up with a spudger.
  • After the cover has been removed, unscrew the M1.6 x 2mm screw from the battery cable with a j000 Philips head bit.
  • Using screwdriver bits that do not fit snugly in the screw head have a tendency to strip the screw and render it unusable.
  • Remove the tape by gently scraping the edges up with a spudger.
Hier Übersetzung einfügen
