Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
The ribbon cables under the battery need to be detached from other electronics as a precaution in case the ribbon cables remain stuck to the battery during removal. Gently lift the flaps on the four ZIF connectors. Use a plastic card to gently pry the battery from the device.
  • The ribbon cables under the battery need to be detached from other electronics as a precaution in case the ribbon cables remain stuck to the battery during removal.
  • Gently lift the flaps on the four ZIF connectors.
  • Use a plastic card to gently pry the battery from the device.
  • There may be glue holding the bottom of the battery to the housing, so it is best to use a card to pry the battery away from its housing. If there is resistance, use a spudger to detach the glue while the battery is partially raised.
Hier Übersetzung einfügen
