Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Using a spudger or plastic opening tool, disconnect the ribbon cable from the right side of the device, where it is attached with adhesive. These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead. These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  • Using a spudger or plastic opening tool, disconnect the ribbon cable from the right side of the device, where it is attached with adhesive.
  • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
Hier Übersetzung einfügen
