Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 5
Wedge a plastic opening tool between the black clip and white module on the large, orange display ribbon in the middle of the circuit board. Pull the clip toward you with the plastic opening tool in order to completely disconnect the display ribbon. The black clip holding this ribbon can fly out if enough force is used. Be careful not to lose that black clip.
  • Wedge a plastic opening tool between the black clip and white module on the large, orange display ribbon in the middle of the circuit board.
  • Pull the clip toward you with the plastic opening tool in order to completely disconnect the display ribbon.
  • The black clip holding this ribbon can fly out if enough force is used. Be careful not to lose that black clip.
Hier Übersetzung einfügen
