Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 6
Label all the cables as you remove them. Work logically. I started top right and went anti clockwise. (this helps to know you haven't missed any when you reassemble.) Theres 2 that have the gold contacts in the clip facing the motherboard... I noted that too. Probably important not to turn them around? Theres 2 that have the gold contacts in the clip facing the motherboard... I noted that too. Probably important not to turn them around?
Remove the cables and label them
  • Label all the cables as you remove them. Work logically. I started top right and went anti clockwise. (this helps to know you haven't missed any when you reassemble.)
  • Theres 2 that have the gold contacts in the clip facing the motherboard... I noted that too. Probably important not to turn them around?
Beschrifte beim Entfernen alle Kabel. Fange oben rechts an und arbeite gegen den Uhrzeigersinn weiter. (Dies hilft dabei, beim Zusammenbau keine zu übersehen.)
Es gibt zwei, die Goldkontakte im Clip zum Motherboard haben ... das habe ich auch bemerkt. Wahrscheinlich ist es wichtig, sie nicht umzudrehen.
