Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 8
Once you have the motherboard out you should have something that looks a bit like this. The CPU is the one that's mounted at the funky 45° angle. Bottom left on the overall photo. On the side of the motherboard that normally faces the back case there's huge Phillips head Spring loaded screws holding the heatsink on, but on the other side the usual torx T10 back to back with the Phillips head things. Four to undo.
  • Once you have the motherboard out you should have something that looks a bit like this.
  • The CPU is the one that's mounted at the funky 45° angle. Bottom left on the overall photo.
  • On the side of the motherboard that normally faces the back case there's huge Phillips head Spring loaded screws holding the heatsink on, but on the other side the usual torx T10 back to back with the Phillips head things. Four to undo.
  • When you have that heatsink off you need to clean the heatsink side with some thermal cleaner. Fixit sell it.
  • The i7 processor is socketed and easy to unclip. There's a spring loaded handle top right orientation in the overall photo although you can't see it because of the heat sink. In the 4th image it's visible to the left of the socket.
  • The old processor lifts out and the new processor drops in be careful to align the processors identically. One corner has an arrow on it.
  • Use new thermal paste between the processor and the heatsink. IFixit sell it.
Sobald das das Motherboard heraus hast, sollte es etwa so aussehen.
Die CPU ist im 45 ° -Winkel montiert. Unten links auf dem Gesamtfoto.
Auf der Seite des Motherboards, die normalerweise dem hinteren Gehäuse zugewandt ist, befinden sich riesige unter Federspannung stehende Kreuzschlitzschrauben, die den Kühlkörper festhalten, auf der anderen Seite der Kreuzschlitzschrauben jedoch der übliche Torx T10 . Insgesamt vier müssen heraus.
Wenn der Kühlkörper abgelöst ist, muss die Kontaktfläche zum Kühlkörper mit etwas Reinigungsflüssigkeit gesäubert werden. iFixit verkauft es.
Der i7-Prozessor ist gesockelt und lässt sich leicht ausclipsen. Es gibt unter Federspannung stehenden Griff (oben rechts im Gesamtbild), obwohl du ihn aufgrund des Kühlkörpers nicht sehen kannst. Im 4. Bild ist er links vom Sockel sichtbar.
Der alte Prozessor kommt raus und der neue Prozessor rein. Achte darauf, die Prozessoren identisch auszurichten. In einer Ecke ist eine Pfeilmarke.
Trage zwischen Prozessor dem Kühlkörper neue Wärmeleitpaste auf. IFixit verkauft sie.
