Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 4
Twist the ignition coil and spark plug boot while lifting it straight up to remove it from the engine. Avoid rocking the coil and boot side-to-side, since this could break the existing spark plug. The procedure to remove the ignition coil and spark plug boot is the same for each spark plug. However, to reduce the chance of dirt entering the engine, only remove one at a time.
  • Twist the ignition coil and spark plug boot while lifting it straight up to remove it from the engine.
  • Avoid rocking the coil and boot side-to-side, since this could break the existing spark plug.
  • The procedure to remove the ignition coil and spark plug boot is the same for each spark plug. However, to reduce the chance of dirt entering the engine, only remove one at a time.
Hier Übersetzung einfügen
