Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet. You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
  • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
  • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
  • You will hear the tabs pop as you separate the back casing around the tablet.
Hier Übersetzung einfügen
