Zum Hauptinhalt wechseln
Englisch
Deutsch
5. Schritt
Use tweezers to gently remove the metal spring from the plastic hook. Due to the tension of the spring, it can be difficult to pull the metal end. You may attempt to use your hands to pull the spring itself if necessary.
  • Use tweezers to gently remove the metal spring from the plastic hook.
  • Due to the tension of the spring, it can be difficult to pull the metal end. You may attempt to use your hands to pull the spring itself if necessary.
  • Take caution to not bend the metal.
Hier Übersetzung einfügen
