Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Once the glue is loosened, you should be able to pry off the battery from the screen. Using your hands, pull up on the battery to pull battery off.
  • Once the glue is loosened, you should be able to pry off the battery from the screen.
  • Using your hands, pull up on the battery to pull battery off.
  • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
  • The battery will be completely disconnected and you can set the battery aside in a safe place.
Hier Übersetzung einfügen
