Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 38 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 8 übersetzen
8. Schritt
While holding up the upper case, pull up the black tab of the silver cable away from its connector. If there is no black tab, you can also use a spudger to gently pry the connector from its housing.  This connector is tall, so be sure to pry straight up. If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  • While holding up the upper case, pull up the black tab of the silver cable away from its connector.
  • If there is no black tab, you can also use a spudger to gently pry the connector from its housing. This connector is tall, so be sure to pry straight up.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  • While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
  • Upon reassembly, there are 4 grey plastic clips on the optical drive side of the keyboard (refer to second picture). They must be installed in their slots for the keyboard to snap in properly.
  • To make the reassamble process easier, it's better to pull out the clips first by pulling it straight up gently. Be careful not to put too much strength because it will break.
Hier Übersetzung einfügen
