Zum Hauptinhalt wechseln
Englisch
Deutsch
Step 2
Locate the memory compartment and undo the screw. Note: It cannot be removed from the compartment door. Prise the door away from the netbook from the screw end. There are clips along the side that hold it in place. Once loose, put the door to one side.
  • Locate the memory compartment and undo the screw. Note: It cannot be removed from the compartment door.
  • Prise the door away from the netbook from the screw end. There are clips along the side that hold it in place. Once loose, put the door to one side.
  • (Image rotated) Undo the screw and remove from the bottom right of the memory compartment. Note: It is not necessary to remove the memory when replacing the Hard Drive.
Hier Übersetzung einfügen
