Englisch
Deutsch
7. Schritt
Lift away the case to reveal the main board(s). The hard drive is clearly visible to the right. There is a cable running over the hard drive that connects the two main boards together. Like the touchpad this is removed by lifting the two black retainers and sliding the cable out. Remove the remaining screw from the bottom right of the hard drive caddy.
  • Lift away the case to reveal the main board(s). The hard drive is clearly visible to the right.
  • There is a cable running over the hard drive that connects the two main boards together. Like the touchpad this is removed by lifting the two black retainers and sliding the cable out.
  • Remove the remaining screw from the bottom right of the hard drive caddy.
  • Raise the hard drive gently using the black tab to the left and slide left to release it from the connector to the right. The hard drive can then be removed.
Hier Übersetzung einfügen
