Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly. Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger. Work your way down the sides to avoid cracking the rear cover.
  • Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly.
  • Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
  • Work your way down the sides to avoid cracking the rear cover.
Schalte das Moto G ganz aus, bevor du beginnst.
Beginne am USB-Anschluss mit dem Ablösen der Rückabdeckung mit dem Finger.
Löse weiter den Seiten entlang ab, zerbrich dabei nicht den Rückdeckel.
[* icon_note] Make sure your Moto G is turned off and that '''any SIM or SD cards are removed''' before beginning disassembly.
[* black] Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
[* black] Work your way down the sides to avoid cracking the rear cover.
