Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 30 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge. The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case. Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
  • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
  • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
Hier Übersetzung einfügen
