Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
2. Schritt
In order to remove the photo sensor, you will have to cut through glue and remove screws. Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
  • In order to remove the photo sensor, you will have to cut through glue and remove screws.
  • Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
  • WARNING: Knives are sharp. Treat them with respect.
  • Now remove the three .15 inch screws holding the photo sensor to the camera frame.
Hier Übersetzung einfügen
