Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Turn your attention to the left side of the cinema display. Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board. Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
  • Turn your attention to the left side of the cinema display.
  • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
  • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
  • Remove the circuit board by gently lifting it from the display.
Hier Übersetzung einfügen
