Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Using the spudger, loosen the casing behind the battery and the two sides. The case should lift easily upwards and outwards towards you if you are facing the battery compartment.
  • Using the spudger, loosen the casing behind the battery and the two sides.
  • The case should lift easily upwards and outwards towards you if you are facing the battery compartment.
  • Make sure the cord that was attached to the Bluetooth cable is not still threaded through the case when trying to remove it.
  • If you feel any resistance, stop. Do not force anything. Go back through the steps and make sure you loosened everything.
Hier Übersetzung einfügen
