Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
After removing the screw, use your tweezers to remove the wire connecting the fan to the board. Do not pull the fan out immediately or it may damage the fan and/or the computer. Squeeze the white plastic part of the wire connected to the computer and gently pull. This will detach the fan from the computer.
  • After removing the screw, use your tweezers to remove the wire connecting the fan to the board. Do not pull the fan out immediately or it may damage the fan and/or the computer.
  • Squeeze the white plastic part of the wire connected to the computer and gently pull. This will detach the fan from the computer.
Hier Übersetzung einfügen
