Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
Unscrew the four screws (4.79x2.33mm) on the metal box using the PH 2 screwdriver. Lift away the metal cover to reveal a circuit board with you hand. Unscrew the two terminal screws (4.79x2.34mm) using the PH 2 screwdriver.
  • Unscrew the four screws (4.79x2.33mm) on the metal box using the PH 2 screwdriver.
  • Lift away the metal cover to reveal a circuit board with you hand.
  • Unscrew the two terminal screws (4.79x2.34mm) using the PH 2 screwdriver.
Hier Übersetzung einfügen
