Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Turn the computer over and open the display. You should see that the keyboard is loose. Before attempting to remove the keyboard, note that a ribbon cable connects  the keyboard to the logic board. Improper removal may damage your keyboard. Carefully lift the front of the keyboard up slightly, and then slide the keyboard towards yourself.
  • Turn the computer over and open the display. You should see that the keyboard is loose.
  • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
  • Carefully lift the front of the keyboard up slightly, and then slide the keyboard towards yourself.
  • Then carefully lift the top half of the keyboard, and rotate it towards yourself.
Hier Übersetzung einfügen
