Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 7
In the next few steps, we remove many components that are very similar to the last 21.5" iMac. The WD Caviar Blue hard drive is held to the front bezel by a few screws and, as always, the SATA data/power connectors. The WD Caviar Blue drive is a non-standard SATA drive. The power connector features 7 pins, rather than the standard 4. The drive also has non-standard firmware. This means you can only use Apple's own hard drives and not any standard after-market SATA drive.
  • In the next few steps, we remove many components that are very similar to the last 21.5" iMac.
  • The WD Caviar Blue hard drive is held to the front bezel by a few screws and, as always, the SATA data/power connectors.
  • The WD Caviar Blue drive is a non-standard SATA drive. The power connector features 7 pins, rather than the standard 4. The drive also has non-standard firmware. This means you can only use Apple's own hard drives and not any standard after-market SATA drive.
  • Removing the power supply requires disconnecting the AC inlet cable from the logic board.
  • The LED driver board comes out next after successfully removing the power supply.
Hier Übersetzung einfügen
