Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
  • Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
  • If you pull the white tabs all the way out, just insert them back in to avoid losing them.
Hier Übersetzung einfügen
