Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 24 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
  • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
  • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
Halte das iPhone mit einer Hand fest und ziehe am Saugnapf, um das Front Panel vom hinteren Gehäuse zu trennen.
Nimm dir Zeit und übe konstante, starke Kraft auf den Saugnapf aus. Die Displayeinheit sitzt im Vergleich zu anderen Geräten sehr fest.
Wenn du zu stark ziehst, könnte die Display-Einheit beschädigt werden. Wende genau so viel Kraft auf, dass ein kleiner Spalt zwischen Rear Case und Display Einheit entsteht.
[* black] Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
[* icon_note] Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
[* icon_caution] Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
[* icon_note] If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
