Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4 übersetzen
4. Schritt
In the top there is a connector where you have to lift the black part of the connector to remove the ribbon.  I used tweezers to lift the connector and to remove the ribbon cable Once the top ribbon is removed there is another cable connected in the middle.  The phone will open up more to give you access.   You will need to lift the black part of the connector to remove the ribbon.  Again, I used tweezers.  The screen assembly should now come away from  the chassis Once the top ribbon is removed there is another cable connected in the middle.  The phone will open up more to give you access.   You will need to lift the black part of the connector to remove the ribbon.  Again, I used tweezers.  The screen assembly should now come away from  the chassis
disconnect connectors
  • In the top there is a connector where you have to lift the black part of the connector to remove the ribbon. I used tweezers to lift the connector and to remove the ribbon cable
  • Once the top ribbon is removed there is another cable connected in the middle. The phone will open up more to give you access. You will need to lift the black part of the connector to remove the ribbon. Again, I used tweezers. The screen assembly should now come away from the chassis
Hier Übersetzung einfügen
