Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 6
If you're just trying to remove the rear panel, you can skip Steps 30 and 31. If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If you're just trying to remove the rear panel, you can skip Steps 30 and 31.
  • If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If your replacement part does not include the plastic hold switch, follow the next steps to transfer the plastic hold switch to your new headphone jack.
  • Remove the single Phillips screw nearest to the hold switch.
  • Lift the plastic portion of the Hold switch away from the orange ribbon cable.
  • Ensure that the black notch lines up with the gray slider during reassembly of the switch (see picture 2).
Wenn du nur das Rückpanel ausbauen willst, dann kannst du die Schritte 30 und 31 überspringen.
Wenn deine Ersatzkopfhörerbuchse den weißen Plastiksperrschalter einschließt, dann brauchst du nur die Kopfhörerbuchse zu tauschen. Beim Einbau der Sperrschaltereinheit musst du auf die Position des Führungsstifts nahe des Lochs der silbernen Schraube achten. Konzentriere dich darauf, dann fällt der Rest an seinen Platz.
Wenn beim Zusammenbau alles verschraubt ist, darfst du nicht vergessen die Schutzfolie von der Kontaktfläche an der Buchse abzuziehen.
Wenn dein Ersatzteil den Plastiksperrschalter nicht enthält, dann folge den nächsten Schritten. Hier wird der gezeigt, wie du den Plastiksperrschalter auf deine neue Kopfhörerbuchse übertragen kannst.
Entferne die einzelne Kreuzschlitzschraube gleich neben dem Sperrschalter.
Hebe den Kunstoffteil des Sperrschalters weg vom orangenen Flachbandkabel.
Achte beim Zusammenbau des Schalters darauf, dass die schwarze Kerbe in den grauen Schieber eingepasst ist. (Siehe Bild 2)
