Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
2. Schritt
Begin by locating the double sided pull tape locations. Do not lift on the battery when doing the following step.  You will bend it.  It is very pliable. Pull the black soft tabs  to release the tape's adhesion.
  • Begin by locating the double sided pull tape locations.
  • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
  • Pull the black soft tabs to release the tape's adhesion.
  • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
  • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
Hier Übersetzung einfügen
