Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
With plastic opening tool, take the display screen out of its socket by gently lifting each corner. Flip the screen up towards the Motherboard that it is still connected to. The screen is still connected. Using the spudger, gently lift the film underneath the display bracket to peel it off. Set aside.
  • With plastic opening tool, take the display screen out of its socket by gently lifting each corner. Flip the screen up towards the Motherboard that it is still connected to.
  • The screen is still connected.
  • Using the spudger, gently lift the film underneath the display bracket to peel it off. Set aside.
  • With the plastic opening tool, gently pry open metal display bracket to remove from the Motherboard.
  • Using fingernail, pry black tape up from zif socket to remove the partially attached display screen.
Hier Übersetzung einfügen
