Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting. Do not pull to remove the casing until all sides are loose. You may break or crack the case.
  • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
  • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
  • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
  • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
Hier Übersetzung einfügen
