Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
With the battery facing up (battery connector on the right), carefully align the exposed portion of the adhesive strips along the lower edge of the front of the battery, and press them gently into place. Take care to line up the strips correctly the first time. Once they adhere to the battery, they can't be removed and reused—you'll have to start over with fresh strips. Take care to line up the strips correctly the first time. Once they adhere to the battery, they can't be removed and reused—you'll have to start over with fresh strips.
  • With the battery facing up (battery connector on the right), carefully align the exposed portion of the adhesive strips along the lower edge of the front of the battery, and press them gently into place.
  • Take care to line up the strips correctly the first time. Once they adhere to the battery, they can't be removed and reused—you'll have to start over with fresh strips.
Halte den Akku so, dass der Akkuanschluss nach unten rechts zeigt. Richte die freigelegten Stellen des Klebestreifens an der unteren Kante der Vorderseite des Akkus aus und drücke sie leicht fest.
Achte darauf, die Klebestreifen beim ersten Mal korrekt auszurichten. Sobald sie einmal auf den Akku geklebt sind können sie nicht wieder entfernt und neu verwendet werden – du müsstest zwei frische Klebestreifen verwenden.
