Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
10. Schritt
Remove the zero insert force connector that's on the back side of the motherboard using a small blue plastic opening tool to lift up the black tab. Then pull the motherboard out of the phone. Pull the motherboard vertically to pull the motherboard from the phone. It should still be attached by a wire on the left side.
  • Remove the zero insert force connector that's on the back side of the motherboard using a small blue plastic opening tool to lift up the black tab. Then pull the motherboard out of the phone.
  • Pull the motherboard vertically to pull the motherboard from the phone. It should still be attached by a wire on the left side.
Hier Übersetzung einfügen
