Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case. Lift up on the back of case. Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
  • Lift up on the back of case.
  • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
Hier Übersetzung einfügen
