Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
14. Schritt
Use a spudger to gently pry up the end of the logic board closest to the dock connector.
  • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
  • There is a small golden grounding tab on the logic board adjacent to the 'Do not remove' sticker. Be very careful this does not snag on the side of the case when prying up the logic board; it breaks easily! If you have signal problems after removing the logic board, check this ground tab.
  • If the board won't lift up, double check to make sure all 8 screws securing the logic board have been removed.
Hier Übersetzung einfügen
