Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
8. Schritt
Using the tip of a spudger to start, peel the adhesive backings off of the strips on the front panel plastic. The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself. The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself.
  • Using the tip of a spudger to start, peel the adhesive backings off of the strips on the front panel plastic.
  • The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself.
Hier Übersetzung einfügen
