Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
9. Schritt
Peel the protective plastic off of the inside of the front panel glass. There are three separate pieces: be sure to peel up the home button piece, center glass piece and the piece under the cables. Failure to peel these up could mean poor adhesion and a murky screen. Try not to touch the inside of the glass to avoid putting fingerprints between the display glass layers.
  • Peel the protective plastic off of the inside of the front panel glass.
  • There are three separate pieces: be sure to peel up the home button piece, center glass piece and the piece under the cables. Failure to peel these up could mean poor adhesion and a murky screen.
  • Try not to touch the inside of the glass to avoid putting fingerprints between the display glass layers.
Hier Übersetzung einfügen
