Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Insert the flat end of a spudger between the midframe and the display. Slide the spudger along the seam between the frame and the display.
  • Insert the flat end of a spudger between the midframe and the display.
  • Slide the spudger along the seam between the frame and the display.
  • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
  • As it releases, pull the midframe away from the phone.
  • The volume control tab may fall off during removal. It can be easily reattached.
Hier Übersetzung einfügen
