Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Locate the keyboard cable on the motherboard.  Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard. Locate the keyboard cable on the motherboard.  Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard. Locate the keyboard cable on the motherboard.  Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
Hier Übersetzung einfügen
