Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Step 1
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases. Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
  • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
  • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
Hier Übersetzung einfügen
