Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 9
There are four black plastic retainers, two on each side, that keep the motherboard fix in place. To get the motherboard out,  stick a plastic opening tool under one top corner of the motherboard and carefully lift  upward using a small amount of force to pop this side of the motherboard out of the plastic retainers. Be careful not to break the black plastic retainers as these are needed to put the motherboard back in place. Be careful not to break the black plastic retainers as these are needed to put the motherboard back in place.
Remove the Motherboard from the Retaining Clips
  • There are four black plastic retainers, two on each side, that keep the motherboard fix in place. To get the motherboard out, stick a plastic opening tool under one top corner of the motherboard and carefully lift upward using a small amount of force to pop this side of the motherboard out of the plastic retainers.
  • Be careful not to break the black plastic retainers as these are needed to put the motherboard back in place.
Hier Übersetzung einfügen
