Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. There is a similar RAM slot located on the other side of the processor.
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. There is a similar RAM slot located on the other side of the processor.
  • We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor. Accessing RAM in the upper slot merely requires removing the heat shield.
Hier Übersetzung einfügen
