Englisch
Deutsch
Step 3
Apply the flat end of a spudger to the left side of the rear-facing camera and carefully lever it out of its recess. Apply the flat end of a spudger to the left side of the rear-facing camera and carefully lever it out of its recess.
  • Apply the flat end of a spudger to the left side of the rear-facing camera and carefully lever it out of its recess.
Nutze einen flachen Spudger, um die Kamera hochzuheben und vom Smartphone zu lösen.
Die Kamera ist festgeklebt. Wenn du Probleme hast sie zu lösen, nutze einen iOpnener, um den Kleber zu lösen.
[* black] Using a singleApply the flat end of a spudger liftto the left side of the rear-facing camera and detachcarefully lever it from the phone.
[* icon_note] There is an adhesive located underneath this camera. If you are having difficulty removing it, use the [product|IF145-198-4|iOpener] kit to heat the phone up and help loosen the adhesive
out of its recess.
out of its recess.
