Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
Remove the two 7.0 mm Phillips #1 screws. Carefully detach the silver plastic cover by pulling both ends off. Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
  • Remove the two 7.0 mm Phillips #1 screws.
  • Carefully detach the silver plastic cover by pulling both ends off.
  • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
  • Separate the silver plastic piece by pulling it off from the middle.
Hier Übersetzung einfügen
