Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 15 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
6. Schritt
Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down. Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
  • Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
  • Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
Hier Übersetzung einfügen
