Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Pull the vibrator motor connector straight away from its socket on the USB connector board. Remove the USB connector board from the TouchPad. NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
  • Pull the vibrator motor connector straight away from its socket on the USB connector board.
  • Remove the USB connector board from the TouchPad.
  • NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
Hier Übersetzung einfügen
