Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit. Lift the contact from the end where the screw was located and pull away from the hatch to remove it. Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
  • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
  • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Hier Übersetzung einfügen
