Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6
Use angled tweezers or an iPod opening tool to slide up the brown connector latch, holding the orange battery ribbon cable in place. Make sure you pull from both sides of the latch. You only need to lift the brown connector latch up about 1-2mm to free the cable. Do not lift more or remove the latch, or you might pull the white connector with it! Don't lift up too far or you could pull the battery connector out of the logic board.
  • Use angled tweezers or an iPod opening tool to slide up the brown connector latch, holding the orange battery ribbon cable in place. Make sure you pull from both sides of the latch. You only need to lift the brown connector latch up about 1-2mm to free the cable. Do not lift more or remove the latch, or you might pull the white connector with it!
  • Don't lift up too far or you could pull the battery connector out of the logic board.
  • Make sure to slide the brown connector directly upwards. The connector is frail and will break if it is accidentally shifted to the side. The connector has hooks at the bottom to hold the cable in place. As soon as you break one of the arms you will have problems putting the battery cable back on. If it breaks put the cable in the slot and then push the brown holder in place to keep the cable from slipping out.
  • Remove the cable from the connector.
Schiebe den braunen Riegel am Verbinder mit einer gebogenen Pinzette oder einem iPod-Öffnungswerkzeug hoch. Er hält das orangene Flachbandkabel fest. Ziehe an beiden Seiten des Riegels. Der Riegel muss nur etwa 1 - 2 mm angehoben werden, damit das Kabel frei kommt. Ziehe ihn nicht weiter hoch, sonst kommt der weiße Verbinder mit heraus!
Hebe nicht zu weit hoch, oder du könntest den Akkuanschluss vom Logic Board herausziehen.
Achte darauf, den braunen Verbinder gerade nach oben zu schieben. Er ist empfindlich und bricht, falls er aus Versehen zur Seite bewegt wird. Unten hat er Haken, um das Kabel zu halten.
Sobald einer der Arme bricht, wird es problematisch, das Akkukabel wieder anzuschließen. Falls einer bricht, schiebe das Kabel in den Schlitz und drücke den braunen Halter herunter, so dass das Kabel nicht herausrutscht.
Entferne das Kabel vom Verbinder.
