Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Gently lift up the black-covered cables that remain connected to the motherboard at the bottom left of the laptop base. Move the cables toward the bottom edge of the laptop closest to you without disconnecting them. Do not pull too forcibly or you could damage your motherboard. Carefully lift up the motherboard and slide the battery to the left to pull it out.
  • Gently lift up the black-covered cables that remain connected to the motherboard at the bottom left of the laptop base. Move the cables toward the bottom edge of the laptop closest to you without disconnecting them.
  • Do not pull too forcibly or you could damage your motherboard.
  • Carefully lift up the motherboard and slide the battery to the left to pull it out.
Hier Übersetzung einfügen
