Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Use Phillips head ph1 to remove four 0.55 cm from the red panel (under mesh). Note: For subwoofer replacement there will be 4 screws to remove and four bolts as well. The bolts are used for alignment and cannot be removed, locate the screws and remove.
  • Use Phillips head ph1 to remove four 0.55 cm from the red panel (under mesh).
  • Note: For subwoofer replacement there will be 4 screws to remove and four bolts as well. The bolts are used for alignment and cannot be removed, locate the screws and remove.
  • The Screws will have 0.7cm in depth
Hier Übersetzung einfügen
