Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 10 übersetzen
Schritt 10
Assuming you have enough wire length to spare, insert the bare wire into a wire butt connector so it just passes the nub on one end.
  • Assuming you have enough wire length to spare, insert the bare wire into a wire butt connector so it just passes the nub on one end.
  • Then use a wire crimping tool to crimp the the butt connector, therefore making a solid contact connection.
  • Repeat for the loose wire into the other end of the same wire butt connector.
  • If you do not have enough wire length to spare, then secure some small gauge wire replacement to bridge the gap. If this is the case you will need at least two wire butt connectors, follow the same steps as above to crimp the wire.
Hier Übersetzung einfügen
